paneling vinyl
Discussion in 'Newbie Forum' started by gunshy, Oct 27, 2007.
  1. gunshy
    gunshy Member
    93
    I'm not a newbie, I have been cutting and applying vinyl many years,
    but my question is newbie type.
    When I was first learning to apply vinyl I was always taught that if
    I was paneling vinyl to start low and the next panel up would over lap
    the lower panel. I notice that allot of jobs I see out there are not done this way.
    Sometimes, depending on the job, it's would be easier to start high and
    work down. How is everyone else paneling?
  2. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    your right. Botton to top is best.
    However, there are more than a few self taughts here who didn't get the benefit of other's experience.
    Botttom to top on a panel leaves no edge to catch water and dirt from which streaks form.
  3. N2Harpz
    N2Harpz Very Active Member
    1,125
    1
    I thought about the water issue , but not the streaking. Good advice!
  4. gunshy
    gunshy Member
    93
    Tech, you ever cut corners on that?
    Sometimes when it isn't convenient to start low.
  5. Ken
    Ken Major Contributor
    5,484
    2
    38
    Feb 7, 2005
    BC
    In what situation would it be inconvienient to start at the bottom?
    Bottoms up!
    Ken
  6. Techman
    8,520
    8
    38
    Jun 24, 2003
    michigan
    Nope.. If you can finish it when the edge is way low.. you can start when the edge is way low..
    I can spot a noob's panel job from the street. If the panel has been up a few weeks you can spot the friggin streaks.
    Even on vinyl lettering with straight tops such as a "T" there is a way to prevent streaks running down the face. Just gotta have some experience.
  7. Ken
    5,484
    2
    38
    Feb 7, 2005
    BC
    Hi Techman..can you enlighten me about your last comment?
    Thanks.
    Ken
  8. gunshy
    gunshy Member
    93
    Such as when the bottom up the decal need to end up at a certain height. I know there are work arounds, just wanted to see how everyone else here a installing.
  9. gunshy
    gunshy Member
    93
    That should have read:
    Such as when the top of the decal need to end up at a certain height.
  10. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    Bottom to top . . . example : House Siding . . . !
  11. Craig Sjoquist
    Craig Sjoquist Major Contributor
    6,746
    4
    38
    Jun 18, 2004
    Orlando
    back to forward on trucks and tailers also
    font crazy
  12. thesignexpert
    thesignexpert Active Member
    841
    2
    Always, always, always... bottom to top & rear to front for all of the reasons listed above. That exposed edge is a weak point (both physically and aesthetically) and it should always be protected. That being said, should the need ever arise where you absolutely have to break this rule then use a SeamSealer pen (or brush it on) to protect and seal that edge.
    Good luck
    Tim Evans
    http://www.thesignexpert.com
    "Practical Help for Sign Professionals"
  13. Ken
    5,484
    2
    38
    Feb 7, 2005
    BC
    Yeah, I saw a Doritos delivery truck a while back..one side was layed down from the back to the front..the other side was front to rear?
    People always look at me funny when i go around a vehicle "feeling" the laps..lol..
    Ken
