tommythesignguy
I have used some newer machines that warn not to run magnetic thru them. Would it be possible to print directly to magnetic with the ribbon machines?
Thanks, I didn't know... the machine was sorta free, so I wasn't that worried about it. If it would work I would use it alot more. For cutting vinyl, it is in slow motion and for printing stickers it's so-so.
Thanks, I am gonna try it.You can print CYM mode or just K from Corel 10 and up. It does spot colors and can print a white base on clear. You could print on the thinner mag material, but for a long run I would use Stouse. For in house, I printed, applied to the mag material and cut with an xacto or a wheel cutter.
Thanks, I guess I'll pass on trying that.NO, The PC-600 maximum media thickness for printing is 8 mil, it was warned that anything over that would probably damage the print head (direct from Roland). I would imagine that the PC-60 is similiar.
