PCut 1200 wrong setings X & Y!?
Discussion in 'Miscellaneous Plotters' started by gvozden, Nov 11, 2005.
  1. gvozden
    gvozden Member
    35
    Feb 12, 2005
    Europe
    Hi, can someone help me with this cutter. I`m going crazy!!
    I have one pcut 1200 and it start cutting wrong on x & y !? I know that you have to adjust X & Y but how can I know what is a right number.
    10 cm is not 10 it`s somethimes more and it going bigger as it going more.
    1meter is about 113 mm. It isnt fix number if you catch me!? It always goes on x little bit and on Y. Rounded rectangle always miss cut! I tryed to find dealer I they only gave me number for "right"set on display. That does not work .
    When I set "right" it is worse then. I have one more cutter and this is a big problem now , I cant work on this cutter precise jobs, it always adds few mm on X &Y . Markers doesnt mach when we try to combine several layers.
    I dont know how to set right that cutter. Is anybody has some similar problem.
    I could try again and measure right missaligment but it takes a lot of time and wasted material, please, can someone help me!? Sorry on my bad english, I speak better than write.
    Thanx in advance!
  2. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    sorry, If you had a standard cutter and common software i am sure I could point a good way to help.. But I am not sure what the problem is let alone how to help you.. I simply do not know
    techman
  3. gvozden
    gvozden Member
    35
    Feb 12, 2005
    Europe
    still trying
    well, I export from corel to PLTDRAW and than cut. On some other tech forum some guy from service told me that a standard setup is X:26170 and for Y:25950. But that only makes worse . Cutter makes biger mistakes in work. Goes even more in x & y. That mistake is not constant , I cant find right ammount of error, if you get me!? If I know 1 cm is 1,2 I could easy calculate error. But when you multiply X and Y error you get something out of range that you set to cut.
    I dont know how to calculate or reset numbers to start cut like when it was like before ( new) . Please if somebody have idea , I tryed everything and couldnt manage to make right setup.
    Thanx for every advice!
Similar Threads - PCut 1200 wrong
  1. msenjur
    5
    136
