Photo Shop
ChicagoGraphics
In Photo shop CS or CS4, while I'm masking photo's out of backgrounds and after I delete what I dont want, the picture comes out looking transpearent. Is there something I'm doing wrong here?
Thanks in advance
oldgoatroper
Roper of Goats. Old ones.
Thanks in advance
Do you mean the entire picture (sort of lensed) or do you just mean the part you erased or deleted?
Sign_Boy
Does it look like any of these?
ChicagoGraphics
The picture I'm keeping looks like if I were to put a 90% lens on it, it's so light I can't see the image. Is there something that should be on or off?
This is the first time this has ever happend.
Sign_Boy
Never had that happen.
Have you tried masking your images using add layer mask?
This is a great tool.
oldgoatroper
Do you have a lens effect set on your layer? (right-click on the layer then check under something like blending options -- I'm using Photoshop 7, so it might be worded differently in your version)...
Sign_Boy
Have you tried masking something else out in a new document?
May be close PS and start fresh.
Is your Opacity and Fill at 100%?
ChicagoGraphics
Yes I tryed masking other pictures, and the same thing. Funny thing is I must be doing something wrong, I tryed it on 2 different computers, one using CS and the other CS4 and the same thing is happening. Opacity and Fill are at 100%
oldgoatroper
Is there an additional alpha channel ? I've seen that before -- screws things up in weird ways sometimes -- problem goes away when the channel is deleted.
Are these pictures you scanned yourself, or supplied by someone?
oldgoatroper
all these pictures you're having trouble with are all from the same camera? what about pictures from other sources?
ChicagoGraphics
Same thing, I tryed different pictures I have in my computer and I just scanned one doing the same thing. I have to be doing something wrong, what I just don't know, I never had this happen before.
boxerbay
just use a different approach until you can run to bookstore and buy PS for Dummies.
Use the pen tool to select around your apple, adjust your nodes if needed, click to make selection - invert the selection and then hit delete.
