Photoshop cs2 cut line ?
Tim Kingston
Yes it is possible, I use it all the time. There are lots of vector tools in Photoshop. I create a path from a selection, as an example, and then export that path to Illustrator. Tim
The Vector Doctor
Chief Bezier Manipulator
There is an export path to illustrator option in Photoshop but it won't automatically happen. It works with live text converted to a work path or any other work paths you have created manually from within photoshop
PatrickW
Then what is the best way to utilize Photoshop? I just bought CS5 and I use Flexi 10. How do you guys design in vector applications, export to Photoshop, pretty it up, and then print if you want a contour cut?
mikey-Oh
patrick, use flexi in the last step for the rip and contour. photoshop'll fit in fine most anywhere before that step
PatrickW
Okay, but what I mean is: suppose I design a logo or some text in Flexi. I export as eps to Photoshop and add a bevel, highlights or whatever. Now I have a raster image with no vectors to use as cut lines. When you import your file back to Flexi you have lost the vector info. When Flexi imports, it doesn't put the image/object back directly where it exported it from, so I guess you would have to manually line up your original vectors/cut lines. Is that how it is done?
mikey-Oh
pretty much how i do it. i think you can also ps filters in flexi within the bitmap menu.
to aide with alignment, you could add a box outside of it all(away from your embellishments) then align x and y
phototec
When you paste a VECTOR image into Photoshop, it will give you a choice of different options, if you select the SMART OBJECT, that vector based image will stay a scalable vector image in Photoshop.
I will typically paste the image twice on two different layers, one as a SMART OBJECT, and the other on another layer as PIXELS, that way I can modify the raster image using what ever filters I need, yet I will have the true vector image on another layer for cut lines etc.
If you use the paste function twice (control V), after making the copy, and paste on two different layers, they will be aligned perfectly.
:smile:
PatrickW
I can copy in Flexi and paste into Photoshop, but it gives me no option for pasting as a smart object. Must only be available when pasting from Illustrator?
mikey-Oh
smart objects are on the adobe side of things, think it asks when you import/place a vector. are you generating your contour cut before you take it to ps? it's easier to make afterwards.
PatrickW
Not a contour cut, just a vector shape. I can copy or cut from Flexi and paste into Photoshop, but Photoshop gives me no "smart object" option when I paste. It just pastes it as pixels. Thats why I wondered if it just works from Illustrator.
LittleSnakey
If you designed it originally in flexi then you have the vector path. Just copy everything, then add a outline at 0 with outline set to countour. Separate the outline then use that to mask the photoshop .jpg file.
Or you can save the transparent photoshop file as a .psd and import into flexi. In Flexi then use the contour cut tool to add the cutline.
mikey-Oh
awe, now i'm confused. got a couple screen shots, maybe i can understand and provide more accurate a solution?
J Hill Designs
dont copy/paste the vector data into photoshop, export from flexi as eps and import into photoshop...then the smart object thing should pop up
signswi
Yep, you want to Place, not Paste. You're linking to external content (ala indesign or illustrator links), whereas copy/paste literally copies and pastes raster data.
One note--if you do create paths in Photoshop for importation into Illustrator for cut paths, you'll likely end up with super choppy paths. Sometimes it'll look like your plotter blade is stippling instead of cutting smoothly. Best avoided unless you have to.
PatrickW
When I open eps, CS5 doesn't give me Smart Object options. I think you need to create a file and then place or import eps, right? But actually I don't know if I need vector data in Photoshop anyway. Like jhilldesigns says, I created the vector data in Flexi, exported to eps, opened in PS and saved as a native file. I imported that into Flexi. Then i can center/center the original vectors over the bitmap and use that as a mask or cut line. Maybe there is a better way to do it, but that worked fine. I think I'm gonna like it!
