Plotter problems
Discussion in 'Summa' started by spacemonkey, Aug 1, 2008.
  1. spacemonkey
    spacemonkey New Member
    4
    Has anyone had any problems with calibration problems? ie. cal. opos,cal. media. And if any, what was your solution? Thanks!
  2. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    cmon man
    Give up some info.
    Who made it\
    what model
    what software
    what OS
  3. spacemonkey
    4
    Well, It's a Gerber P2c plotter, using Composer to cut and am running XP. It seems that when I run Cal. Opos. and weed the rectangle the result is a Cal Failed. When I run Cal. Media it tells me "this media cannot be sensed with opos" obviously. How can I get this calibrated to sense registration marks? I am a newbie at this so I must be missing some piece of the puzzle. Thanks.
  4. dclet
    dclet Active Member
    666
    Dec 23, 2004
    fdsfdf
    Gerber P2c = SummaCut series
    you're using black vinyl? Either clean it well ( the vinyl ) or try sticking dark blue just to get the offset correct.. you're taking the square out not weeding around it....
    is the opos working at all ( is the red light showing on the vinyl) there may be something blocking it.
    you can set media calibration manually
    http://www.summausa.com/downloads/opos2_manual.pdf
    On a side note I didn't know Summa also licensed the opos tech to gerber...heh
    Summa Users
