I have a Mutoh ValueJet 1638X and I am running my color through Colorgate. I am trying to match a PMS 185C and I just can't seem to dial in this color. I have my color swatch matches on and my Lab color is coming out at 50.2/76.5/48 and my Delta E is a 10.3 reading. I wrote a profile for this material and a majority of the typical PMS colors that I use are fine, but this just seems to out of gamut. Any suggestions.
Thanks,
Jeremy
Pantone 185C is likely to be moderately out of gamut, but you should be able to get much closer than 10.3 dE if:
1) Your ink restrictions (primary channel ink limits) are reasonably set.
2) The machine is in a linear state.
3) Your ICC Profile is accurate to the present behavior of the machine.
4) the RIP is recognizing the spot color.
I checked on one of my HP Latex machines running a standard calendared vinyl (3M IJ40) and the predicted dE 2000 for that color is 4.3, which is a good (but not great) simulation of the Pantone. It's definitely out of gamut as seen in the image.
Paul
