pnc 960 cutter
Cadmn
I tried the other day to cut a side panel for sons car 72" & my pnc960 wouldnt cut that far what program is recommended for bridge from corel It has to be cheap I dont normally need that long of a cut
OldPaint
what program are you cuttin from? and did you try to reset your page size in you in the driver setup?
Cadmn
OP using corel 12 & yes set my size to 72"L 15" W
was told I needed bridge program but if others are doing it without then why cant I ???
OldPaint
960 isa 24" plotter right? youre not setting the page right. it will default to 62.99. you have to manually reset this value to 80", or 96". and corels page will do up to 150 feet x 150 feet.
