pop-out / perf-cut decals on CJV
fresh
Is there anything more than increasing the pressure if I want to cut the stickers through the backer paper?
Doesn't doing this destroy the blade? What about the cutting strip?
We also have a Graphtec FC7000, but for print&cut we usually use the Mimaki.
OmegaAdv
I have Graphtec CE6000 and it have that function perf-cut where the blade have other nest infront of the usual cutting nest. See your FC but if you don't have other nest don't increase the force you will damage the cutting pad.
boxerbay
there should be a forward position in the blade holder so the blade is in the gutter and not on the strip. completely unscrew the blade holder. remove the blade then insert it in the forward slot.
you might also have to twist out more blade. we use 2 different holders so we dont have to keep re-adjusting the blade tip. CB09 for kiss cuts and CB15 for perf cuts.
boxerbay
fresh
Are you talking about using your graphtec or mimaki?
I actually just figured out that Mimaki calls it "half cut" which makes googling a little bit easier :)
fresh
ours doesn't look like it has two positions...
