Post & Panel with 3 post
juan45215
We're about to install 2 signs on 3 post to form a "V" shape. This is pretty standard to form a 2 sided sign. Is there a standard angle to use?
petepaz
i don't know if there is a standard. i have bought some 2 panel-3post sign frames from 4-ever frames and they are 90 degree angle. they where going on corners of the road so it was perfect. i guess if you are making it custom you should make and angle that fits the traffic pattern.
Billct2
Around here some towns have a "spread" limit, over the distance it's considered two signs not a single double face sign.
A good many of ours are around 120°....... or a little less, but like mentioned, you should base it upon the needs of the site.
