S
scarface
Guest
Honest, lately i have been using the big squeegee for anything medium-large size. Works wonders
Here's another option using a second roll of mask. You should squeegee it afterwards.
Bob, I think the bubbles will occur if you try using your hands after the premask is cut off the main roll. When I use my hands there is a little tension which allows the mask to hover over the graphics until I gently rub them down. I then go over with a squeegee and we get abspoulutely no bubbles.
I understand you completely, but unless you're some sort of mutant your hand is anything but straight and flat. That being the point.
Assuming you mask starting on the right and working the mask down to the left. The object is to push the mask into contact with the vinyl such that all air between the mask and the vinyl is pushed to the left. You simply cannot do this reliably with your hands, you need straight flat edge to insure complete contact. While you might have some bizarre massage technique that gets you by using your hands it's far easier, approaching effortless, with a 12" or so squeegee.
+1 Works great - absolutely no wrinkesOne other thing I forgot to mention...sometimes I find it easier to cut a piece of application tape lay it sticky side up on my table. Basically applying the graphic to the application tape. I don't know why it's easier but it works for me.
