Rat_Fink
Hello - I am using Flexi 10.5
This seems like it should be very easy, but I have not found a setting - let me explain.
I am printing on 54" material, but have to contour cut on a 30" cutter (my larger cutter is down at the moment).
so I would like to print 2 different designs on the 54" material - then laminate - then I will cut the material in between the 2 prints so I can fit each into my 30" cutter.
This means that I would need to be able to print both files at once, but with separate registration marks.
Is this possible?
Is this possible?
