jkdbjj
yep, how about you? Are you considering it?Has any one used monitor color calibrators?
Best solution is to print color charts on the various materials you use and then match the colors you'll need for each job, I've been doing it for years and it works great every time.
where can I find a chart to print on my media
I'm with jkdbjj on this 100% of 100%. Color charts are for the uninformed...
...Proper calibration/profiling/linearization will also save a bunch on ink consumption. Our ink consumption went down considerably after we set up a proper color managed workflow...
...Time savings in design and layout are another huge advantage. No need to constantly refer to color charts and manually enter color values...
...I just chuckle to myself when I hear sign guys beaking off about how fool proof their color chart color management system works. It's just proof that the fool that was fooled was not the intended fool but none-the-less the most appropriate fool.
Au contraire. Color charts are for those that comprehend that what comes out of the print is the truth. To operate otherwise is to rely on the amusing notion that what you perceive on a monitor is the truth and somewhere, as if by magic, the same thing necessarily will emerge from your printer. The operative word here is 'necessarily'.
There is no causal connection between a monitor and a printer no matter how intensely and devoutly you tend to profiling and calibration and dancing naked around a fire waving beads and rattle chanting "Booga Booga".
Please explain just how, exactly, printing from a color chart manages to use more ink than trusting your luck to that last profile job. Feel free to use as many charts and graphs in your response as you might deem necessary.
Being a long time devotee of color charts, I can say with some authority that I might glance at one once in a while. For the most part, I know exactly which colors come out which way. This tends to make the constant color chart referral which seem to bother you rather unnecessary.
One can only wonder what the above might say had it been written by a sentient being.
I suppose for you it may be perceived as some sort of magic. When it comes to wide format printers the "truth" is that garbage in = garbage out. If you're comfortable letting substandard work out the door then I guess you don't have too much to get excited about...
With a proper profile you would be laying down only enough ink to render the required color without unnecessary ink saturation. No charts and graphs required.
...So by being a "devotee" magically makes you some type of "authority"? Sorry but you're not fooling anybody except yourself. You're most certainly not fooling me!...
Quit being a knob Bob!
If a proper ICC color management workflow is somehow offensive to you then go ahead and do things your way. I'm not forcing you to use a proper ICC color management workflow but I will tell you that the way your doing it now is most certainly NOT color management now matter how hard you try to mangle the English language in a pathetic effort to make yourself heard.
You make it annoyingly clear that you don't have a clue about color management yet you insist the masses bow down before you and take your "Color Mismanagement Sermon" as gospel. My answer to that is you can kiss my petunia. You are clueless!...
...As for your extensive experience with computers let me tell you one thing. I have children that grew up before computers when your parents were still finding their way to earth...
