It all depends on what you want to do, how busy you are, turn around time, experice, etc.... I would stay away form a print/cut machine and it limits you. You can't print while your cutting and vise versa. Also if the machine goes down for some reason you SOL, where if you have separate machines you can still print or you can still cut. Also depending on the price you could probably pick up a new HP entry level latex machine and a entry level plotter with warranty. With latex you have no fumes, no need to out gass, less worry about maintenance and upkeep. Overall unless you doing specific work that requires metallic or white I really would research the latex machines. While I was at one shop my boss wanted the Roland Versacam cause of the option to do metallic's, so we picked one up, the metallic ink is 'ok' but there was no real market for it, it's expensive and ended up wasting most of the ink through the machine as it went through it's cleaning cycles. Now I'm at a shop that just switch from eco-solvent to HP Latex and the difference is pretty nice. I don't see us going back to solvent. The health benefits alone I think are worth it.
