Shortly after purchasing my HP9000 back in 2005, I did some research and found
DCA04 NDI cleaning solution by Lyson which is sold by NAZDAR, I was told that this
solution is used for cleaning true solvent grand format printers.
I used this solution since then on the wipers and caps. However, I read your thread
about using Butyl Carbitol as a cleaning solution and have used that instead of lyson
for the simple reason that BT is not evaporate as quickly as the DCA04.
On the last 6 heads I just recently reclaimed from a printer which sat for several years in a storage trailer under the
hot nevada sun, I managed to clear all the orifices in all the heads. The heads were installed
on the printer just yesterday and today I will be priming the system, and clearing any errors
that may appear and see if they discharge properly. Hopefully the DCA04 solution did not dammage any of the head's
I used the last of the Lyson solution in the process of cleaning those heads.
I believe that because of the agressiveness of the solution, I was able to unclogg the heads
using ultrasound and an aftermarket ink pump.
I will post again once I have results of the reclaimed heads.
