printing photos
Discussion in 'Roland' started by graphix, Mar 21, 2010.
  1. graphix
    graphix Member
    404
    Dec 15, 2005
    Ohio
    i use gcvp profile.printing on 651 or orajet.
    when i print a photo some parts of photo prints like a black when it should print the color it sees...
    example a picture of someone weaing a royal blue shirt the shirt in the phot has like a different color of blue (do to the lighting of the photo) but it still is blue but when i print it prints lke black where that shade is it seems to fill in black at several differen spots where shades are...its just something with profile or media not sure i am new to this but i know you all call this something when this occurs..but anyway the heads are firing fine and all other vectors print nice but photos is different...
    any comments or suggestions on how to print photos on vinyl...thanks,,
  2. graphix
    graphix Member
    404
    Dec 15, 2005
    Ohio
    do i need to raise print head as well as get paper and profile?
    thanks
    roland sp540
  3. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    Printing on 651? Are you seriously printing on oracal 651 vinyl, that might be part of the problem. First off use media made for printing, then if printing photos try doing it as a tiff file.
  4. GVP
    GVP Active Member
    829
    19
    18
    Nov 11, 2005
    Swift Current, SK
    You don't need to raise the heads. We use the GCVP profile on most Oracal calendered vinyls with good results. You might want to try outputting the file as RGB instead of CMYK - we've had better luck using that with photographs
  5. threads1
    threads1 Member
    282
    Jan 31, 2009
    Ocean City, Maryland
    Like Mosh said......651 is a cut vinyl. It's not made for printing on. Why aren't you using GCVP?
  6. graphix
    graphix Member
    404
    Dec 15, 2005
    Ohio
    i do use GCVP for most things..
  7. dolce05
    dolce05 Member
    235
    Jan 18, 2008
    Long Island New York
    print on vinyl thats supposed to be printed on and make sure your not making the photos larger then they can be made and having color drop out
  8. graphix
    graphix Member
    404
    Dec 15, 2005
    Ohio
    do i output in versa i out puted from flexi in rgb as a eps and took it to versa..thanks for helping all but still have problems printing photos on banners as well they print dark...
  9. sfr table hockey
    sfr table hockey Very Active Member
    1,212
    Jan 24, 2009
    Alberta
    What ink are you using? What temp are the heat settings?
    What rendering intent are you using for the photos? Perceptual is best for photos. Next is what Dither type was used. Try other profiles.
    For me using a converted CJ 500 I found that a WTBM (for solvent not eco sol) profile worked well on a lot of things but due to using non Roland inks the colors are off on photos. With made profiles the colors are better but ink levels need to be adjusted to keep from getting too dark like you said.
    Try dropping all ink limits to 70% just to see if the photos are any better.
    I printed on Oracal 751 and it prints real nice and they say its for thermal print but not anything about eco sol ink.
  10. graphix
    graphix Member
    404
    Dec 15, 2005
    Ohio
    how do i do this on a roland sp540 using versa works
    thanks
  11. TresL
    TresL Very Active Member
    1,010
    Oct 24, 2005
    First, 651G prints great on a Roland SP....
    We use it for basic decals and go through about 1-2 rolls a week, it has a better white point and stronger adhesive than the cheap print vinyls.(3164, 3640, 3651)
    Lam with 210.
    For pics, try and print the JPG file unless you are doing contour cutting.
  12. sfr table hockey
    1,212
    Jan 24, 2009
    Alberta
    Let us know what setting you are using right now. If you can go over the setting the best you can it might help others to say what you might be doing right or wrong. I don't use or know versaworks so I can't say where to find all those settings but they should be listed and you should be able to see what options you have.
    Ink is a key for the colors.
  13. DRamm76
    DRamm76 Member
    496
    1
    I know some guys who take the risk and go cut vinyls to run through their machine. When I try to suggest otherwise, I get the "no offense, but it works and it's cheaper" so for the time being, it is the thing to do for them..UNTIL all of a sudden a problem goes wrong then it usually starts with "what the hell is wrong with my machine"..
    I know some people have had success with it, but that doesn't mean it's the best thing to do..I can run my hand over a heat press as close to the platen as possible..doesn't mean I am never gonna get burned. Thats just my opinion
