BRUSHMARKS
i am trying to cut decal kits with decals ranging from .25x.5 up to 4x6. It is on 3651m 36" w/ a lamex 5mil luster polycarb laminate. cutting on the mimaki cg130fx. i have all 3 pinch rollers set on edges and center. When i run through the cutter it wanted to pop up in between the pinch rollers causing it to get blade drag (the blade is scratching the laminate and is noticable). I called our mimaki tech support to see if they have and trick to fix this or if you can add more pinch rollers. They said no to both. So question is: Does anyone lam an dcut with thicker poly carb that has th esame problem? Has anyone found any tricks to get it to work correct?
