Hi, new to this forum.
I Picked up a GX24 about 3 weeks ago and out the box it was super easy making perfect cuts on Oracle 631. For the past few days ive been noticing everytime the blade cuts into the vinyl it moves/shifts the vinyl around bunching it up between the rollers as if more rollers are needed to keep the vinyl flat. These shifts cause the cutter to leave incomplete cuts in lettering forcing me to tear the vinyl when weeding. Also been having to use a little more force to cut the same material ( first used 50g, now needing 80g with pen force dial maxed). Not sure whats causing this, i replaced the blade thinking maybe its dull, but still same thing. Did a google search and this Seems to be a common issue but cant find the cause or solution.
Not sure if roland checks this forum, but any help will be appreciated
