Jim Hill
After replacing dampers, wipers, scraper and ink cartridges I believe I have found the problem why my SP-300 won't print when using magenta.
The small tube that the magenta damper goes on is only half the length of the other tubes so I believe this is problem. Is this tube tapered on the top or just it just look that way. I have about half the tube sticking out that the other dampers have.
When I use a syringe attached to the bottom of the damper the magenta flows right into the damper.
How big of a job is it to replace this part?
Is it tech time or I can I do it?
Where to find the part in another problem.
Thanks Jim
Thanks Jim
