Profile for Phototex, what are you using?
Velocity
Getting ready to land a job using the Phototex repositionable material and was curious to know if anyone has a favorite canned profile for this material?
Thanks for any input.
J
Replicator
I print on a roland inkjet printer.
Usually use a AB vinyl or Clothe profile.
I also usually get the best color buy turning off the icc output.
Best to test with small samples.
Velocity
Thank ya Rep, I will give it a spin
Using EcosolMax inks, do I need to leave a border around the image?
Replicator
If your planning on hand cutting it, then it wouldn't be a bad idea !
My Printer/Plotter will not contour cut through the Photo-Tex .
Velocity
Hrm... What model are you using? Im running a 540vc and it seems to cut this material pretty good.
I have only cut smaller sample pieces.
So hand cutting it have you had any problems with the edges curling?
KR3signguy
I've been told that it can be run on a solvent printer by some. A true source told me that it's really best suited for aqueous & dye sub, chroma and shouldn't be run on a solvent printer. Apparently Phototex has a brand new version specificly for solvent. The original issue was the ink really seaped into the fabric leaving an overly washed out appearance. A sample roll is on the way. The repositionable tack on this fabric makes it an installers dream.
m.hafenbrack
We got some of the new solvent material for our Roland XC-540. We were told to use MCVP : Matte Calendered Vinyl profile and it seems to work good on our test prints.
dlndesign
Thats one of the profiles I was told would work. We got a sample roll and I wanted to make sure that I can print a nice sample. Thanks.
We profiled the Phototex solvent material on a Roland machine (SP) running Roland's EcoSolMax inkset. It is an easy media to profile if you have the tools to make custom profiles.
Bob
Spencer McMurtry
Thanks! im using this profile on a sp-300v, i turned the cut speed down to 10. cuts and prints GREAT! the edges don't fray at all..
escortle
My Versa Works does not have that profile
I am using Versa Works & I do NOT have that profile? Where can I downloaded it? Thanks
