Tovis
First step should be finding the ink limits. Inks plateau at a certain point and by some phenomenon actually scan with less density if you over ink. The ink limit should be set to that plateau and this usually takes a while to find. You find this by printing the lin target, scanning it, looking for gradations to move up, not stay the same, and not to move downward. I’d start with the individual ink limits at 90% and move downward to find your ink limit. Be sure that color management and icc profiling is turned off when doing this.
The second step is to make a lin file by scanning that target printed with the magical numbers you found.
Install that lin and set the lin method you would like to use.
Next, you’ll want to find out the multiple ink limits and set a cap to where they run good without pooling or looking odd.
After that you’ll want to print the profile, scan it, and let whatever software you have make the profile. I use the substrate name to name the profile.
Profiling is an extremely finicky process. I have an i1 and ambient light throws it off or makes it difficult to scan substrates especially textiles. What I found is it is best to shut the lights off.
If you attempt to make a profile without finding the ink limits, or skipping the linearization process you are more than likely going to have a profile that doesn’t do so hot or has will have a limited gamut.
From time to time printers drift and this may need to be redone in the future.
