PSA Roll Question
Tovis
PSA is typically suppose to be rolled with the print outward correct, like how it comes on the roll to prevent ripples and other bad things. Especially with lamination over it.
sfr table hockey
For sure when it was laminated to roll with print side out. Not sure if it could cause issues when not laminated to roll the other way.
Are you talking more on air release media or vinyl in general?
Tovis
No, was just curious. At a sign shop I use to work at everything PSA was rolled print side out and I think I remembered that it was because the end customer usually preferred that.
anotherdog
Allways out. I may roll banner in for protection, but vinyl especially laminated should be rolled out.
bad juju to roll it any other way. Even more so if you use UV stiffer inks.
