purchased signlab 8 - program stopped working
Discussion in 'Signlab' started by gabagoo, Oct 22, 2008.
  1. gabagoo
    gabagoo Major Contributor
    5,720
    104
    63
    Oct 10, 2006
    Vaughan, Ontario
    So I purchased an upgrade to Signlab 8, and truthfully I loaded it into my laptop but really have not used it yet. In any case they require you to send the old dongle back in a supplied envelope which we did 2 days after we received the new software. I have heard nothing from them and today the program says that my trial period is over. $875 for a trial? Sheesh. I phoned there offices and got voice mail and left a message of the importance of having the program working and we are dead in the water without it, with no call back yet. Good thing I have 2 work stations here lol. Not sure why I upgraded anyways.
  2. signage
    signage Major Contributor
    9,513
    75
    48
    Oct 5, 2005
    Penn
    When I upgraded I didn't have to send back my dongle all they did was give me new licensing files!
  3. CS-SignSupply
    CS-SignSupply Very Active Member
    Common practice for most software vendors that require dongle. Recommend you supply tracking number to the supplier you purchased from and if shown as delivered, they should be able to email you a code or new password or license file or whatever you need.
    Standard Postal Mail is not recommended as it is next to impossible to truly track your package and get proof of delivery. UPS/FedEx/DHL whatever it takes.
    If your key was new enough, you may not have required a new key to run the newer version.
    Best of luck.
  4. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    I believe it is often on upgrades from parallel dongles that a new dongle is required.
    I would consider trying to re-install the program if there are not a lot of customizations done to your workspace or pallettes.
    I would also hunt down some better numbers to call, including a sign supply you might have purchased Signlab from, or even a supplier you purchase a lot of other stuff from, who sells Signlab, as they may have a better number.
    2 days without a call back is ludicrious... you need a better phone number
  5. gabagoo
    5,720
    104
    63
    Oct 10, 2006
    Vaughan, Ontario
    Thats how they treat us Canadians it seems. We sent the old dongle back via UPS so there will be a trail and a signature, but I find it strange that I have to call them to get it working, and they have never bothered to try and contact me. I can see nothing has changed with their methods. In fact when I gave them the dongle number off of out origianl dongle that is still here they said they don't even have it on file!!! nice
  6. CS-SignSupply
    Your best bet would be to contact the reseller from which you purchased from... They will have inside contacts. Be sure to send them the UPS Tracking number as confirmation. Probably already done this.
  7. gabagoo
    5,720
    104
    63
    Oct 10, 2006
    Vaughan, Ontario
    well I decided to call back and this time I got someone and he is going to e-mail me the codes. Not sure why they didn't call back, but then I am guilty of that at times lol
  8. CS-SignSupply
    Seeing as the dealer can not issue or create such codes, they are often caught in the middle. BUT, they should be your advocate and first line of support to the manufacturer.
    Good to hear it will be resolved for you.
  9. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    Not with Cocut... Upgrade with their package is FREE and never sand back a dongle..
  10. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    I kept and used the same dongle when I upgraded to v8
  11. gabagoo
    5,720
    104
    63
    Oct 10, 2006
    Vaughan, Ontario
    I moved from the old paralel dongle to the usb dongle
  12. CS-SignSupply
    There you go.
