question about the designjet 5500
capista
hello people
i have designjet 5500ps uv ink i want to ask about the printhead life how long!
i heared that the average is about 4000 ml of ink
is that true !
thank you
Robert Boyd
4000 sounds a little high, but a new printhead only costs about $150
and you replace it yourself. I have a 10 year old 42" 5000(dye) and a 7-8 year old 60" 5500UV.
capista
thanks for the replay
what i mean is when i should change the printhead after how much ink consumed
BigfishDM
Here is a trick that will double your head life:
When you think you need to replace the head get a damp paper towel and a dry paper towel and place the contacts of the head on the damp towel then on the dry towel, do this about 12-15 times and you should get a lot more life out of the head.
Bly
There is no set amount of use. Some heads last 10 litres and some 2.
Do an image quality test print 1 to see how they are firing.
