Click to Support Signs101 ...
Hi, I have a mimaki CJV-30, and I used Rasterlink... The prints started to come out bigger than the original files, for example: a job with 3000mm comes out with 3030mm...
Does anyone know what to do to fix it?
Is it in the feed direction? Run the feed compensation in the setup menu, it'll print a test pattern, change the values till it's correct. Instructions are in the user manual under Media Correction.
Yes, I understand, I haven't adjusted it for some time, the 2 lines cannot be superimposed, I'll adjust it and see if it solves the problem, if not I'll reinstall the rasterlink. TKS
