Re relettering Lexan?
Discussion in 'Electric Signs & Channel Letters' started by bayviewsignworks, Feb 9, 2010.
  1. We have a customer who wants us to take the vinyl off a Lexan lit sign. It is white with black vinyl letters on the lower half. The want to take off those letters and put on some new info? Will there fading or a silo of the letters when we take it off? Obviously they're going cheap on us.
  2. Just Another Sign Guy
    Just Another Sign Guy Very Active Member
    3,057
    will there be fading? or ghost or discoloration... almost guarantee it, depends on how long it has been up.
    make sure you explain to them the cost of removing the vinyl and adhesive compared to the cost of a new face. in my experience the savings simply are not there in most instances and then you are still left with a sign that is less than perfect in most instances.
  3. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    +1 on what Dan said. If they are being that cheap on you have them bring you the face with the old stuff removed and ready to letter. Otherwise price a new face.
  4. Mainframe
    Mainframe Very Active Member
    Some of the jobs like this are not so cut & dry to answer, if this is a steady customer & he is determined to get the face re lettered, he will find someone to do it & you could lose the customer, also it depends on how much work you have, if you charge for r&r the face with a truck, remove the vinyl, clean the face & re letter it, there is not a lot of out of pocket cost involved, if you would have been standing around sweeping the shop, you are ahead of the game, if you want to do the job, explain to the customer when you take off the vinyl, there will be ghosting, then scrub the face with SOS & soft scrub with bleach & hose it down, letter it upside down from the old lettering & you should be fine. As long as there is not too much ghosting, which I have not seen yet.
  5. basicmetal
    basicmetal Member
    61
    Jan 17, 2007
    Wisconsin
    There will always be someone out there that is willing to do it, but it doesn't change the fact that it probably shouldn't be done. Just remember that if you do it, you put your name & reputation on it as well and the client will most likely forget all of your warnings when talking to his friends about how bad his new sign looks.
  6. Billct2
    Billct2 Major Contributor
    7,463
    642
    113
    Mar 12, 2005
    New England
    Yes there will be fading/ghost, how bad varies....
    If I understand correctly you are only changing text on half the sign...
    so go ahead, just let them know the ghost/fade may be visible.
  7. G-Artist
    G-Artist Active Member
    526
    That kind of job should be bread and butter.
    I'd love to do 3 a day instead of 2-3 a week.
    Sure there will be some sort of ghost outline. So what? Depending on the viewing distance it may not even be noticeable. Just clean it well before applying the new legend. In any case, tell the client to expect that.
    If you do electric work, it would be a perfect opportunity to sell the client on replacing all the bulbs while you are there vs. a later service call @ $90 plus bulbs.
  8. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    No out of pocket costs? How about the 3 hours lost trying to clean that monster. Around the first hour and 1/2 it starts to get close to the cost of a new sheet. Never mind the sun stains and the clean up of the shop afterwards.
  9. UFB Fabrication
    UFB Fabrication Member
    166
    1
    If its a flat face and small than likely cheaper. If its a pan face likely not. Give the customer 2 options and what either would cost. Let them chose, as long as you are getting paid and will hopefully make a profit who cares.
  10. 731SignTech
    731SignTech New Member
    9
    If the customer dont wanna buy a new face , When you peel the vinyl off , reletter the other side instead of the side it was on.
  11. artsnletters
    artsnletters Member
    282
    1
    18
    Feb 28, 2007
    Upland CA
    sell the cheapo new faces...the old ones will no doubt be yellowed and maybe even a bit brittle (depending on it's age)...guaranteed you'll have mega ghosting when you take the old stuff off.
    Tim
  12. Westcoast Sign Guy
    Westcoast Sign Guy Very Active Member
    1,221
    11
    38
    Jan 3, 2005
    San Diego, CA
    Polycarb is the worst plastic that yellows so fast leaving ghost images
    I would love to be a fly on the wall on some of these sales meetings that take place with a client with some of these people.
    What happened to doing a job right, and right the first time around, not just collecting your money and walking away. But leaving integrity, and with?
    I don't know, maybe this is just one of those clients that just leaves their own image to the bottom line
  13. night eagle
    night eagle Active Member
    611
    27
    28
    Mar 9, 2009
    Crowley tx
    what if you break it trying to pull it out of the sign or taking it down...
    i dont think its worth the hassle...quote a new one, and dont tell your customer thats what your doing...take the old one down...clean it on your off time or when someones standing around, and resell it used.
    mark galoob
Similar Threads - relettering Lexan
  1. Jo-Jo
    5
    417
