Really Need Help Please
graphixstation
Hi All,
Im having a problem(Sort of big problem), I have Windows Vista Business and have CorelDraw X4 on it. I have a Roland SP-540v and VersaWorks 3.0. When i do a logo or art work in CorelDraw and then put a cut path on it and send it to Versaworks it doesnt come up with the cut path around the artwork and wont cut. Can anyone help me out?? Any help would greatly be appreciated. Has anyone else had this problem and got it fixed??
Bigdawg
Just Me
Are you defining the cut path as a spot color called CutContour ? It must be spelled like that with the capitals exactly as I typed them.
Jester1167
I found that you have to create that NAMED color swatch in the existing Custom Spot Colors Palette in Corel. Any other palette and it won't work.
And you have the color named correctly?
send me a file and I will look at it to see if it your computer of file...
save it as corel 13..
send it to
4310 at sbcglobal.net
graphixstation
Yes have done that and it is 100% CutContour. When i pit the hairline around the object and export as an eps, Versaworks still doesnt see it??
Maverick Signs
it must be named corectly, saved in the spot color pallet ( once saved though you can drag it into your primary palet). you should use a line wheight of .001mm. you must also make sure the color is defined in versa works they must both be the same
