Need Help Recommended vinyl and laminate to wrap corrugated shipping containers.
Discussion in 'General Chit-Chat' started by Pam, Jan 30, 2020.
  1. Pam
    Pam New Member
    7
    Jul 11, 2012
    Savannah, GA
    Looking for advice on the best vinyl and laminate to wrap shipping containers. The containers will be new. I understand how to measure, using a soft measuring tape. Just need advice on the material.
    Any information would be greatly appreciated. TIA
  2. Andy D
    Andy D Very Active Member
    2,499
    485
    83
    Oct 20, 2014
    Hattiesburg, MS
    Do you mean the large steel containers used on ships?
  3. Boudica
    Boudica I'm here for educational purposes.
    775
    229
    43
    Dec 21, 2018
    WA State
    I would go with a cast vinyl - due to the contours of the ribs - or whatever those are called. channels?
  4. James Burke
    James Burke Being a grandpa is more fun than working
    3,536
    521
    113
    Jan 2, 2010
    Mitten State
    Another, perhaps more accurate way to measure is this:
    Take a strip of vinyl, say 36 inches long by 2 inches wide. Starting in the middle of a standing rib, continue to apply the vinyl and try to get it to end atop another standing rib. You may need more or less vinyl to accomplish this, but make it an easy number to remember.
    Then, measure the overall length of the applied vinyl across the tops of the ribs. Divide the original vinyl length by this measurement. Hint: the number should be greater than 1.
    Multiply this factor by total length of your intended installed design to obtain your total cut vinyl length.
    This method is especially helpful if you're aligning multiple panels, since you will have accurate intervals by which to tile your layout (preferably seaming at the tops of the ribs).
    JB
    • Like Like x 3
  5. #racewraps
    #racewraps @printwithspeed
    54
    13
    8
    Dec 12, 2017
    Grand Rapids, MI
    We typically use Avery 1105/ 1360 might be overkill but makes the install much smoother.
  6. kerwinchua
    kerwinchua Production Manager
    Hi Pam,
    I would recommend 3M 3920 high tack vinyl. You can apply any UV overlaminate on it and the high tack adhesive will make sure it won't peel off even in cold weather installs.
  7. Pam
    Pam New Member
    7
    Jul 11, 2012
    Savannah, GA
  8. Pam
    Pam New Member
    7
    Jul 11, 2012
    Savannah, GA
    Thank you
  9. Pam
    Pam New Member
    7
    Jul 11, 2012
    Savannah, GA
    Thank you.
  10. McDonald Signs
    McDonald Signs McDonald Signs & Graphics
    108
    17
    18
    Feb 11, 2013
    Guin, Alabama
    High tack 2mil vinyl. You might also consider using some 3M Primer for better adhesion down in the creases in the valleys at the base of each rib. We did some wrapping on some new shipping containers and the valleys were the only place anything lifted. On the second container we used 3M Primer and it seemed to make the vinyl stick alot better.
  11. James Burke
    3,536
    521
    113
    Jan 2, 2010
    Mitten State
    I brought in a 20' shipping container four years ago to use as a sandblast booth. When I inquired about purchasing another one two years ago, the prices had gone up considerably...in part because one Chinese manufacturer temporarily going off line for a while, and also because of the new rules about the aqueous based paint they must now use (taking much longer to cure).
    In short....the paint is different on new containers now compared to four years ago.
    The certification tag on the door identifies the year of manufacture. If I were you, I'd try to find a new container and test your vinyl for adhesion.
    JB
  12. JBurton
    JBurton Signtologist
    2,180
    485
    83
    Sep 28, 2017
    Arkansas
    I'd consider where the container will be used before selecting a high tac vinyl. Just saying, lots are used for storage/signage options and never shipped anywhere cold.
    Depending on what they were wanting, I'd probably go with a mask and paint solution, but obviously this might not be possible. What's the wrap going to look like?
  13. signpromarshall
    signpromarshall New Member
    3
    Nov 21, 2011
    Minnesota
    3M ij360
    It is made for a his type of application.
    Do no have to do all the crazy mathematics to have enough vinyl.
    Look it up !
