thanks and did that too but the problem is the software not seeing the reg marks after sending from illy
I caught that from your description.
When I have had this issue it is usually related to the naming of the top 3 layers that CM generates when you set the crop marks.
If you alter or hide them they won't show up in CM when you go to cut.
I haven't looked into what exactly Illy is doing to cause the issue but did come up with a work around to save the prints.
In Illy. I snap small markers at 2 apposing crop marks. Deleted the top 3 CM layers - snap a rectangle to my markers - made new crop marks using the "convert a rectangle" option - resave the file.
It is a little tricky to get the rectangle sized and set exactly in the right place but after you've done it once it's not hard at all and beats having to reprint when all you need is a contour cut.
wayne k
guam usa
