remove rivets... how?
Discussion in 'Vehicle Graphics' started by Marlene, Jun 30, 2011.
  1. Marlene
    Marlene Major Contributor
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    I did a search as I remember Flame saying he removes all the rivets from a trailer when he works with one but what I'd like to know is how do you remove them?
    I did a trailer yesterday and would have loved to remove the rivets in some of the areas where I applied vinyl (it wasn't a wrap, just lettering and graphics) but wasn't comfortable mucking around with a customer's trailer when I had no idea how to remove the rivets. how do you remove them and then put them back in place?? I am so clueless, any help would be grat, thanks
  2. cajun312
    cajun312 Active Member
    597
    3
    18
    Jun 26, 2005
    Louisiana
    Screws you can remove, rivets can not be removed without destroying them.
  3. Baz
    Baz Very Active Member
    Many trailers have screws and not rivets. Those you can remove and put back in after. Other trailers have actual rivets and those cannot be removed. I personnaly like the trailers that have NO screws or rivets :Big Laugh
  4. Marlene
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    the ones I had had were dome shaped, approx .5" or so in diameter with a indent in the center that looked like it might need a special "key" type bit to unscrew, was that a screw or is that a rivet? can I tell by looking a it or do I need to try to unscrew it and if it comes out it's a screw and if not, it is a rivet?
  5. HulkSmash
    HulkSmash Major Contributor
    8,159
    140
    63
    Sep 10, 2010
    Denver.
    to remove rivets, you have to drill them out... but you can replace them after
  6. insignia
    insignia Very Active Member
    If they're removable it'll have a 8-point small star-shaped hole in it. You actually use a #2 square driver to remove these. Home Depot sells the bit.
  7. Baz
    #8 Robertson bits (square) work as well on many of those star shaped screws. I think you can buy those bits failry easy in your stores but not the screws! Something about Phillips bits being american and Robertson being canadian.
    Even though the Robertson screw is way more superior to Phillips! :popcorn:
  8. d fleming
    d fleming Very Active Member
    2,770
    229
    63
    Nov 28, 2007
    Middleburg, Florida
    10-20 bucks for a bit assortment package at lowes or hd will cover most funky screw heads you find. Make sure you have the correct bit and not something that "almost fits and will work" so you don't strip the head.
  9. Baz
    Agreed that everyone should buy a package of assorted bits. Just mentioning the #8 Robertson because it has helped a few times when i didnt have the star shaped ones on hand.
  10. diamondavenue
    diamondavenue Member
    78
    If its an american trailer and looks like a star it is most likely a #2 square, it seems kind of odd when looking at them if you dont do it very often. Just dont remove all at once or you have a bigger issue.
  11. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    16
    nah just take the side of the trailer into the shop to apply :thumb:
    (kidding, of course)
  12. SignManiac
    SignManiac Major Contributor
    8,494
    37
    48
    Mar 25, 2006
    Mars Florida
    If it is in fact a rivet, you have to drill out the center and the head comes off. Replacing them requires new rivets and can use either a hand squeezed rivet gun or a pneumatic if you have an air supply. When replacing existing rivets, make sure to match the head length and the stem thickness. They also come in either aluminum or stainless.
  13. Marlene
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    that's what my Canadian husband says too!
    thanks to all of you for all the help. I have a box of different shaped "keys" and will try them the next time I get one of these things to letter. it sounds like I can't mess it up and remove something I can't replace without a ton of work and that was my worry. I was afraid to mess with it and then find out I needed a special tool to replace them.
    thanks!!!!!!
  14. bob
    bob Major Contributor
    5,273
    306
    83
    Nov 4, 2005
    earth
    A rivet is a one time use fastener. It works by deforming one end to clinch the pieces being fastened and must be destroyed to be removed.
    A screw is merely an application on of the fundamental machines the inclined plane and the wedge. It does not have to be destroyed in order to remove it.
    Most of the fasteners used to fasten panels on trailers etc are #2 square drive. For which bits are available most anywhere.
    There's a bewildering array of screw drives available from common [plain old slot], Philips, Reed & Prince [which is hard to tell from Philips], square, allen, Torqx, and beyond.
    Basically if it was screwed in it will unscrew.
    Depends. The square drive is one of many drives designed for hands off robotic automation. The Philips is not. Both have their places.
  15. Christian @ 2CT Media
    Christian @ 2CT Media Major Contributor
    4,579
    709
    113
    Jun 15, 2009
    Mesa, Arizona
    I really don't think he meant to actually remove the rivets... Im pretty sure he meant he cuts off the vinyl that covers the rivet.
  16. Marlene
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    I really aprreciate all the help!
  17. Baz
    Name me an application where a Phillips screw is better than a Robertson. That Phillips design is .. ahem ... screwed. It strips to easy. You can't put any pressure on it when screwing and even the drivers strip easy. Tight spaces where you cant use two hands to put in one screw can be very frustrating. Face it .... It's crap!
  18. bob
    5,273
    306
    83
    Nov 4, 2005
    earth
    Philips is auto-centering and in any semi-automated application is superior to most any drive into which the bit must be precisely located.
    The problem with Philips is that you must assert down pressure sufficient to overcome any turning resistance. In other words, as long as you're pushing down harder than the force it takes to turn it, the drive will never strip.
  19. Baz
    It sucks plain and simple yet you cannot admit it! :ROFLMAO:
  20. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    Marlene, don't look now, but I think bob's hitting on you! :smile:
