Removing left behind Adhesive...
Discussion in 'Tips & Tricks' started by TheSellOut, Jun 12, 2010.
  1. TheSellOut
    TheSellOut Very Active Member
    1,355
    Maybe I'm just high from the Rapid Remover® but this seemed to work really well.
    Spray on Rapid Remover®, let sit for a minute, (here's the tip) use a Mr. Clean Magic Eraser® to wipe adhesive off.
    It was just a couple of truck doors I cleared off...but it really went smooth...so I thought I would share!!
  2. Bradster941
    Bradster941 Very Active Member
    2,190
    One thing that I’ve found that works really well after removing large panels is to spray down what’s left behind with your favorite remover till it gels into the “snot” balls when scraped with the little chisel.
    Then, take dish washing soap and water in a bucket, dip a old rag, wipe down the surface.
    A minute or two later, use the garden hose while wiping lightly with the rag.
  3. Gordy Saunders
    Gordy Saunders Member
    423
    Gasoline does it without turning it to snot. Remover cost $42.00 a gal.
    Gas $2.54. Gas works just as well.
  4. Pat Whatley
    Pat Whatley Major Contributor
    8,592
    86
    48
    Sep 29, 2003
    Wetumpka, AL
    Other than the fact you look like a hack and smell like gas for the rest of the day.
  5. mark in tx
    mark in tx Very Active Member
    2,081
    Oct 25, 2005
    Harker Heights, Texas
    I've never had Rapid Remover burst into flames.
  6. TheSellOut
    1,355
    I must have been high because I tried this again yesterday and it did not work so good!
  7. PNH Jake
    PNH Jake Member
    125
    1
    18
    Aug 22, 2009
    New Hampshire, USA
    I just use the Rapid Remover and the Lil'Chisler. Works like a charm. After the bulk is gone I will spray with R.R. again and wipe down, then clean with soapy water or some other cleaner (I haven't had any bad chemical reactions yet...)
    If you read the packaging for the Magic Eraser it says NOT to use it on vehicle paint... I know someone who did and it took the clear coat right off...
  8. PNH Jake
    PNH Jake Member
    125
    1
    18
    Aug 22, 2009
    New Hampshire, USA
    As an aside... the stuff is kind of intoxicating... I try not to use it indoors too much... Starts off smelling nice -- "Oooo is that orange?" and then slowly kills brain cells...
  9. TheSellOut
    1,355
    yeah I can't stand it...always well ventilated, gloves, and mask!
  10. Marlene
    Marlene Major Contributor
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    Rapid Remover works the best. I've tried other stuff and not so great and a lot of work.
  11. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    3M adhesive remover and a plastic razor blade. Has not failed yet.
    Gas? Hope he is not a smoker....
  12. signgal
    signgal Very Active Member
    1,364
    Dec 29, 2009
    +1 My detailing pal gave me a spray bottle of something he discovered, to try. Haven't had a chance, yet. I'll let ya know.
  13. d fleming
    d fleming Very Active Member
    2,778
    230
    63
    Nov 28, 2007
    Middleburg, Florida
    Been using Zep Big Orange degreaser and graffiti remover for awhile now. Works just as good as RR but at a much better price.
  14. threads1
    threads1 Member
    282
    Jan 31, 2009
    Ocean City, Maryland
    Goo-Gone @ Home Depot.......still gotta do a little rubbing though.
  15. PNH Jake
    PNH Jake Member
    125
    1
    18
    Aug 22, 2009
    New Hampshire, USA
    Having used Goo-Gone, Orange Clean and other cleaners and struggled to clean vehicles and signs, I just about sh*t myself the first time I used Rapid Remover. It was like the skies opened and a light shone down on me -- I swear I heard angels singing. I won't go back... even if the Rapid Remover is bit more pricey, the amount of labor it saves is amazing.
  16. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    some time ago several of us tested the various concoctions of remover.
    All of them loosened the adhesive turned it into snot. But removing the snot was the challenge.
    The cheaper ones needed several tries to get it all off. So cheaper was not better. It took more of it to do the same work so in the long run it was more expensive. Plus it took more time.. Rapid Remover was the overall best.
    That was enough proof for us.
  17. Jillbeans
    Jillbeans Major Contributor
    14,457
    19
    38
    Dec 24, 2003
    Butler, PA
    I have found the RR to work the best with the least amount of work.
    I'd rather pay more for something if it actually does the job.
    Time is your friend, too.
    I line the floor with paper towels, spray the RR, leave it sit a little bit till it turns to glue to goo. Then use the Chizler and swoosh it down onto the paper towels.
    Re-spray with RR and wipe again with paper towels, then clean with Rapid Tac.
    II Jake you crack me up.
    Love....Jill
  18. Signworks of Algoma
    Signworks of Algoma Member
    171
    1
    18
    Sep 6, 2005
    Algoma, WI
    I couldn't agree more, II Jake. I've used Goo-Gone. RR is like Goo-Gone X100.
  19. Gene@mpls
    Gene@mpls Very Active Member
    2,010
    88
    48
    Jun 17, 2003
    Blaine, Mn
    A bug sponge kept in a air sealing-type plastic box with a 1/2" of RR in it will
    take the residue off quickly. Has just the right amount of abrasion and can
    be easily cleaned.
  20. signgal
    1,364
    Dec 29, 2009
    Bug sponge?! Do tell....
