mopar691
Digital Designs,
I've looked at the tech support notes from your case and I have a hunch. According to our notes, you're not just doing a standard contour cut, but a "perf cut" That requires a few extra steps that, if not performed correctly, will cause the alignment to be off.
At one point in the notes, it mentions that when you wanted to do the regular cut, the plotter was performing a perf cut.
That indicates to me that the settings in Flexi aren't quite correct. That would also explain why the Graphtec is doing the same thing as the Q54.
It is a somewhat complex process, but if you'll check all the boxes in the correct order, it works. I've written a blog article about this that you may find helpful. Please refer to it, but also feel free to contact me and I'll walk you through the process.
Here's the link.
http://www.signwarehouse.com/blog/?p=4152
Ya if that is what he is doing and he is new to perf cutting he is going to wreck alot of material to get it figured out, need to set not use same profile for each color, set up 2 contour colors in your artwork and make sure you tell flexi to sent the correct profile to the plotter before cutting, pause between colors, switch the blade location manually, then hit start again.
Also make sure your colors are output in the correct order or it will perf first. And tool location is correct within the profile editor on the plotter for each specific cutter.
I perf cut every day and love it, yes I did mangle about 50 yards of material before I got good at it. It takes alot of setup time and has a steep learning curve.
