Roland Cutting Issues
Cameron Hayes
Hi All,
Been working on this issues for a while now, and I am getting nowhere.
When I print/laminate/cut stickers certain cut points do not cut, causing the excess vinyl to be extremely difficult to remove and there are little dags holding waste to product.
I have tried changing blades, blade offset, cutting strip, and have tried a few different things inside Corel.
Attached is a sketch of where the issues are happening.
Any help would be fantastic thanks!
SignMeUpGraphics
Super Active Member
Any photos of the result as it comes out of the cutter rather than a diagram?
Have you correctly set the blade depth and force?
Buy original blades, if they are Roland branded make sure they're new. Change cutting strip. Use higher pressure.
