sfr table hockey
With regards to the Epson 3000 print heads, are there some dampers that fit a little more loose? I have had some dampers come with a red o-ring inside and now some with a blue o-ring. The original had a black o-ring but I assume they were for the waterbased inks. The ones with a red o-ring seem too loose.
The dampers for the newer Roland printers look the same in a photo but are these made with a slightly bigger diameter opening where it goes onto the printheads?
Those who have the 3000 printheads, are you finding the dampers to fit tight enough and what type are you using?
