BigfishDM
I was getting ready to buy a latex printer for wall murals, vehicle wraps, decals, and banners. Now after reading about the L360 and L560 series here having the same issues for wall murals it confirms my concerns from the past couple of years.
I just have a couple questions for latex owners if they don't mind to answer.
Does the color panel issues happen on all media types on long runs?
We print our vehicle wraps using 3M cast wrap vinyls. We only use PhotoTex for our wall wraps and wall based logos. We only use JetFlex for our banner runs. I had hoped to be able to use multiple latex printers to print production runs on multiple printers for the same project.
Rotating the panels when printing long runs for wraps.
Does this allow you provide a sellable product in terms of quality that your company can stand behind?
Do you print on PhotoTex series media?
If so, what are your thoughts on how the two work together?
Do you print on JetFlex series media?
Do you print on 3M IJ180-CV3-10, IJ180-mC, or LX480mC series media?
Do you own both L360-L560 series and the larger format LX3000+ series or the LX1500 series?
Does the larger format latex have the same issues with panels not matching when used in a panel layout system?
How would you rate the larger format series for banners?
How does the larger format series compare to UV printed banners in terms of scratch resistance?
Thanks for your time and input.
I would be willing to put a machine in your shop for a few months at no charge so you can see how these machines run and I bet your results would change your mind. For every negative complaint about an HP, there will be 50 positive statements.
