roland pnc 1100
Discussion in 'Roland' started by te, Dec 30, 2006.
  1. te
    te New Member
    13
    hello,
    i`m a new guy to the vinyl business here in austin texas and i had a quick question.
    just bought a pnc1100,in graet shape(from the looks of it) can`t get my flexi 6.5 to work with it.
    my question is...do i need a driver or something?
    thanks,
    te
  2. Ian Stewart-Koster
    Ian Stewart-Koster Active Member
    843
    15
    18
    Sep 27, 2003
    Qld, Australia
    Yes, you do need a driver or something...
    What operating system are you using (win XP, w98se...?)
    You need a driver from www.rolanddg.com for the operating system you are using, and then the control panel of the plotter needs setting up with the right options selected.
    You'll need a parallel port printer lead, not a serial lead.
  3. te
    te New Member
    13
    thanks ian, couldn`t figure out why i wasn`t connected, and of course i have the serial lead.
    that helped alot.
    thanks again
  4. Ian Stewart-Koster
    843
    15
    18
    Sep 27, 2003
    Qld, Australia
    The pin out connections on the roland serial lead have a couple of wires swapped over- I can't remember which ones- but a standard serial lead will not work!
    You'll need the panel set for hgpl language, mode2, free y or rotate Y (if using XP), Free x if using win98se.
  5. Ken
    Ken Major Contributor
    5,484
    2
    38
    Feb 7, 2005
    BC
    You may also need to rotate the XP to YZ for complete compatability.
    Also, you should have another drink, as I am doing right now..
    I find the downloading to be quite enjoyable.
    Cheers!...Ken
  6. te
    te New Member
    13
    Thanks guys....surely it couldnd`nt have been as simple as hooking it up and ready to go.
    thanks again....te
