Tim Aucoin
I think the original 2nd question was asking about when you do a sheet cut after a print; The material is fed an inch or so forward, then the cut is made. I think he's asking if there is a way to stop the material feed before the cut is made so there's less waste. ? That's what my decoder ring says anway....
If your decoder ring is correct, then the simple solution is simply to use the directional button on the printer to back the material up the distance it will move forward before hitting the cut button. Should accomplish the task!
