but that's what ebay is for...Lot of parts are not available. anymore. For example encoder boards.
Amazon has them too.but that's what ebay is for...
In 25 years, I have never replaced an encoder board on a 300 or 540.Lot of parts are not available. anymore. For example encoder boards.
Heads are easy too. when changing out dampers, you are only 6 screws and 2 springs away from replacing the heads. Manual alignment and then digital alignment all done in about 30mins.Depending on what needs doing they aren't complicated to work on. Encoder strips are super easy. Encoder boards are easy. Ribbon cables are easy, but I had my wife help since her hands are small. She fished them right through in about a minute. Cap tops are easy, just don't lose the springs underneath. They can fly out. Dampers are easy too. You get the idea.
Never did a head replacement though.
Me two times. By the way: the SP300 is available since September 2003, so around 18 years, the SP540 since late 2004, so 17 years. Just about „25 years …“.In 25 years, I have never replaced an encoder board on a 300 or 540.
https://www.sign-in-china.com/products/15129/generic_roland_scan_motor_for_sp_300_sp_540.html and obsolete in your own words.. Learn where to source partsMe two times. By the way: the SP300 is available since September 2003, so around 18 years, the SP540 since late 2004, so 17 years. Just about „25 years …“.
Scan Motors are not available anymore too.
I hope you will get one when you order it. And it will be in the correct specifications.https://www.sign-in-china.com/products/15129/generic_roland_scan_motor_for_sp_300_sp_540.html and obsolete in your own words.. Learn where to source parts
I order and fit them to all 300 and 540 printers I sell. They are correct specification and have never had a fail on them. Scan motor, endcoder strip, captops,dampers, pump, carriage bearings, and heads are all replaced before I send a printer out and have never had a complaint.I hope you will get one when you order it. And it will be in the correct specifications.
Same place https://www.sign-in-china.com/s/ssr15xw1uu.html it's a standard bearing on most modelsTerry01, where do you get your carriage bearings From??
