Roland vp540 repair
Zoogee World
Domed Promotional Product Supplier
I'm not in your area, but what seems to be the issue, it might be something you can self repair?
netsol
you will need. printhead, dampers, captop(s), wiper(s), orings
flush solution, syringe & probably handheld vacuum pump (makes it easy) & set of new inks
smart to buy service manual & download operation manual
not sure if this is one of the machines that locks you out of service menu
netsol
i would buy the service manual, $12.99 isn't a lot of money.
there are free sites, they are all trying to trick you into downloading malware/spyware.
many of us buy our printheads from solvent inkjet.com
they are merchant members here, good pricing, and offer free tech support/advice by email (quick response) if something goes sideways
they can also sell you the other parts at a good price
i think i purchased 3 dx4 heads & a dx7 in the last year from them.
if you buy from them, their tapered syringe is $6.99
DL Signs
Never go against the family
Let me know if you need the service manual, I have a LOT of them covering most of the older 540 Roland models at home... Think I have that one too.
Mactastic
Sign Maker
It's a discontinued product so it will be difficult to source parts, and get a technician to repair it.
petepaz
with all the parts and labor you need might just look in to a new printer, maybe see if they will give you anything on a trade in
Zoogee World
All consumable parts are available for those printers. Discontinued indicates they don't make it as a model now.
Exactly, also means a certified Roland Tech can't work on it either. As long as your handy, those older models are easier to work on yourself.
Mactastic
Sign Maker
OP was asking if someone in Southern California can repair his VP-540. It sounds like they need major parts replaced, one that is not a consumable.
DL Signs
He said it's been idle for two years.
If it wasn't flushed and prepped it could need new lines from the cartridges to the waste tank (readily available), new heads & pump (also readily available), caps, dampers, & other misc parts are all still available. Running a full new ink delivery system like that would probably run 4-5 grand doing it yourself. That is if everything else is in pristine condition, low use, and worth investing that much into. Hiring a tech, you're adding labor, and parts markups if you don't shop around and furnish them yourself, and techs won't even work on older models unless their private contractors, or moonlight. Both options kind of go into the "just buy another printer" territory, lots of working used ones out there in this price range, and it's not that much under new printer options. Quite the dilemma, to fix, or not....
Terry01
How do you come up with 7-8k?? Search 32437257839 in aliexpress
DL Signs
Read closer, 4-5 grand... Not for just lines, but full ink system from cartridge to waste tank. A full set of DX4 heads, new pumps, lines, dampers, cap tops, wipers and misc. 6 heads alone would be over 3k, the rest a grand or so.
cornholio
VP's only have 4 heads...
Problem is, that the mainboards of these printers fail and are no longer available from Roland.
If it's not a VPi, then you won't have IPC and this is likely to give banding, except all heads print perfectly.
DL Signs
Ahhhh.... Didn't look it up to see if it was a 4 or 6 head. That would make it cheaper to fix, but if it's one with mainboard problems, and no IPC, it's hardly worth it then. My first Roland was an SC Pro-II, those were rock solid printers.
spb
✨鞄➕
What's IPC?
(edit: Intelligent Pass Control, obviously)
