Roland VS-640i Error reading second crop mark
Discussion in 'Roland' started by Mata, Aug 3, 2020.
  1. Mata
    Mata Member
    37
    3
    8
    Feb 26, 2018
    London, England
    Hi everyone
    I've been trying to cut a printed graphic all afternoon and I'm getting an error.
    It finds the 1st crop mark fine, when is starts moving along to read the 2nd crop mark, it stops every 6 odd inches and moves the media goes back slightly, when it finally gets to the position of the 2nd crop mark, it's unable to read it as there is nothing there as it's too far back.
    What is causing this?
    I have tried cleaning the sensor and there doesn't appear to be anything on the print to stop it. I just can't figure it out. I cut the previous panels fine.
  2. Medina Signs
    Medina Signs Old Member
    23
    5
    3
    Dec 17, 2011
    Medina Ohio
    Did you try a second print and have the same problem? I've seen it happen when the first crop mark read was not read correctly due to a finger print or some other problem (adhesive on the clear dark or to thick), on the clear laminate -
  3. Mata
    Mata Member
    37
    3
    8
    Feb 26, 2018
    London, England
    Hi, no I didn't think of putting another print in, I'll try that tomorrow.
    If that is the case, is there anyway I can replace the first crop mark and it still work? I don't fancy printing it all again.
  4. IsItFasst
    IsItFasst Member
    375
    12
    18
    Jan 16, 2008
    USA
    Sometimes on specialty vinyl I take a permanent marker and fill in the marks with more color just in case it isn't thick enough to read. The sensor could need an adjustment too. I've seen this before where it will read the first one as the threshold was just enough on that one but not high enough on the second. Sounds odd but worked for me one time.
  5. Medina Signs
    23
    5
    3
    Dec 17, 2011
    Medina Ohio
    I would try using the black marker before trying to add a crop mark. You would not get the crop mark placed accurately. If you have another job ready to go with crop marks, run it and see if your read crop marks is working correctly. Then you may have to re-print the job you are having trouble with.
