Need Help Roland VS640
MP Custom
Hi All.
Can anyone point me in the right direction to get my black printing properly? All new Dampers fitted. New Cap Top. Felt and Wiper replaced .Head soak done.
Is the head stuffed?
Thank you in advance.
Mark
PS Test print attached
Darryn
Hi All.
Mark
Hi Mark,
Does it get any better when you run a Medium clean? I get that after a couple of days of no use, and it usually takes 3 or so Medium cleanings. If no change, maybe it's clogged.
Best Regards,
Darryn
MP Custom
Hi Mark,
Best Regards,
Darryn
Hi Darryn. Thank you for replying!
Here is the result from after 2 medium cleans and a powerful. There seems to be no change ( or very little)
Any other suggestions?
Thank you again
MP Custom
If it doesn't change when you do a cleaning, it's most likely clogged and you'll need to replace the head.
Thank you Joe.
I was sort of expecting that. It will be $4000 AUS. Approx job. Travel time alone for a tech here is $800 AUS. Still getting passable prints if I print in High Quality via VersaWorks.
I have an ultrasonic cleaner. Do you think that might do more harm than good?. I will try with the old head when I get it replaced.
MP Custom
I read somewhere to try a 48 hour head soak, then some cleanings. They said if that doesn't fix it, nothing will.
Thank you mate. I will try the 48 hour soak.. (boy.. that is a long soak) Have a few days of work to get through first. I will update, Just in case anyone else has the same issue
player
I remember reading some time ago ultrasonics are not good for the heads. I don't have first hand knowledge though.
MP Custom
Noted Mate. Cheers. Will not do on my only money maker!. Will be an experiment when new head fitted
PS. Thank you to everyone who gave advise.
So glad I found this Forum. I am 300kms from the closest Technician and all help is appreciated!
Joe House
Sign Equipment Technician
1. Is your Ultrasonic cleaner compatible with solvents? I don't think most of them are. You don't want to ruin your machine trying to salvage a dead head.
2. I loved into ultrasonic cleaneda a while back and found the results to be inconsistent once you got past the manufacturer's advertising. But it's worth a try if your cleaner is compatible with the solvents.
Good luck
