I purchased an XR640 and began using it. Print quality was outstanding but when i went to cut with it, The cutter ran well the first 3" (of the 60"width) but stopped from 3" to 8" and then started cutting perfectly from 8" to the rest of the width. My initial thought was that there may be a kink of perhaps shorts in the cable card that carries the cut information, but in further inspection, I noticed that the cutter was going through the contour motions but simply not dropping the knife.
If that wasnt weird enough, I purchased a 2nd unit that has the same issue only in a different place. At the point, I decided that this can not be a unique problem but when getting on line and hunting I have not found anyone with a similar problem. Perhaps I'm not describing the issue well enough in my searches but I have tried many different descriptions to the problems and spent quite a bit of time looking through general cut issues with this model only to find things like "replace cutting strip" or clean and "inspect blade holder" ect. Has anyone else experienced this issue? if so I would love to know what became of it or what was needed to correct it. Thank you in advance for your time
