round corner machine for dibond, aluminum and coroplast
bigben
Not a newbie
I'm looking for a machine to make round corner on a variety of stock. It goes from paper, dibond, aluminum and coroplast. I've made a search on the forum and the accutter seems to be a solution. I would like to be able to cut 3mm and 6mm dibond and 0.63 aluminum.
What woul you suggest me?
Thanks.
Ben
GB2
Old Member
If I were cutting aluminum corners, I'd be ordering an Accu Cutter 80. I have a Lassco Wizer CR50 and I'm thinking about trying it on 3mm aluminum composite today. I'll let you know how that turns out but if anybody has any info on that before I ruin my cutter, please let me know.
Grizzly
It’s all about your print!
Rounded Corner Smashing
I'm looking at getting a accucutter cornermate plus and wondering if someone can give some feedback.
We cut our blanks first and then print and clear coat through a roll system.
I'm wondering if the accucutter smashes the corner in a little.
If this is the case when you run it through a roll coater the edges don't get coated since they are a different thickness.
Jeremy
moonrakercat
I finally bought this one for 150$ and it work like a charm.
Desktop Round Corner Cutting Machine
Hi Bigben - sorry to open this old thread up - at the beginning of the thread you mentioned you were looking that would work with 3mm or 6mm dibond - and at the end of the thread you mentioned you found something you were happy with - the hand model from asc365 - you posted a link to it also.
I saw in that thread a post about the xpertsignplus 4 sided metal professional die that works with an arbour press - but it is also very expensive.
I have a job where I need to corner round a bunch of dibond 3mm - just touching base to see if your unit would work with the 3mm - have you tried it ?? (I may consider purchasing the same unit if it does)
Any help you can give is appreciated.
Thanks- Moonrakercat.
bigben
Not a newbie
Yep, work perfectly for the 3mm. I use it few times per week and it still work flawless.
