Royal Sovereign rsc1401c laminator only runs in reverse
tjm2
I have a Royal Sovereign rsc1401c laminator that only works in reverse. I am not able to increase speed in order to activate forward movement. Any suggestions?
tbullo
Superunknown
It could be a switch on the pcb board. There are 2 of them (blue rectangle), 1 for forward and 1 for reverse. Take back cover off and you will see the board. You can hear (and feel) them engage when you press the button. I'd check that first. I just got my board back from being repaired from that smoked resistor.
tjm2
Did the speed light move when you pressed the speed button before the repair?
