Click to Support Signs101 ...
I am going to try to use the OPOS on my s75. Anyone familiar with this process? I will be printing to a DC3+, laminating and then using the s75 and OPOS to contour cut. Thank you for any information you may contribute.
We don't print with a DC3 but OPOS is sooooooooo easy as dclet puts it, nothing to it at all, works perfectly every time. Out of curiosity, why are you not doing the cutting on the DC3?
If you have the manual there is a section on OPOS cutting
Basic Description:
*Download the lastest cutter tools
*Add short cut in Corel or Illustrator
*Corel you select your image and click shortcut for opos markers (3mm square each corner of graphic) print job, laminate
*Send cut file to opos cutter and line up first registration marker
it will find the other marks and cut
If you have any additional questions please call Summa Tech Support and they can walk you through the process
We just got back from ISA and ordered a S75. I'm looking forward to running this plotter though its paces. Looks like a good machine. We've always used graphtec or Roland... this is our 1st Summa.
