Hi All
I have a problem with my printer, it gives me this error after trying to separate the cutter carriage from the printer carriage if i make a Print&Cut demo, or i try to make a print&cut job.:
Internal error Mseperate_dispatch: Mistake to separate print carriage
Its a printer that has been bashed around, that i have rebuild, it runs fine and i have adjusted most or all the things i have to, i think.:
Motorbalance
limit position
encoder check
Cutdown position
enviromental match
Lock pos.
and more
I think all is correctly adjusted but i am not 100% on this
it will print or cut fine without any problems as separate jobs, only the separation for the combined jobs is a problem, after it does the mismatch i have to make an encoderstrip check to remove the error, in order to be able to make the cutter measure material size again.
Right now i am out of ideas how to proceed to solve this problem, i hope that some of you guys could help me to guide me in the right direktion.
I think this error have to apply to the other roland models too, so if you have the solution for one of the other models, pls dont hesitate to share it.
Kind regards & thanks for a great board
Jakob
Motorbalance
limit position
encoder check
Cutdown position
enviromental match
Lock pos.
and more
Jakob
