SC545 with bulk ink - wall mount?
intensegraphics
I bought my used Roland a couple of years ago. It came with a bulk ink system using Triangle Inks. Due to space issues, I am wondering if anyone knows if the tanks can be mounted on the wall instead of the end of the machine?
TIA!
Michelle
intensegraphics
I am attaching a couple of pictures. Sorry they aren't the greatest since they are off of my phone.
My machine came all set up so I was curious about if they needed to be at a certain level.
I have issues once in a while with the color dropping out on me, and after going over everything else a tech suggested it may have something to do with the bulk system.
I am in a very confined area and have to swing one end of the printer out to get behind it to load the media. I thought it possibly could be jostling the tanks enough to cause some sort of issue. Hence the thought of wall mounting them.
Any thoughts?
Michelle
intensegraphics
I must admit, I am a little confused. I will add a picture of the rear of the machine.
The lines wouldn't even reach from the other end of the machine.
CS-SignSupply-TT
Sorry for the confusion. Excellent picture! It is worth a thousand words. I would NOT mount on the wall. However, you might want to consider mounting the BULK INK on the black space ABOVE the ink cartridges. Upon further review, I think NOT. Space considerations as they are, I would leave well enough alone
