Screen Printed or Laser Engraved Plaques
rdm01
I need about 150 metal plates (4.5" x 10") with screen printed text and solid color logos (one color, black). At first I was thinking laser engraved, but with the text being black and everything else bare metal maybe screen printed would be a better solution? Is this something that is possible with screen printing? They would need to go on .040 or even thinner metal. Attached is a mock up with logos removed.
  • laser_etch.pdf
TXFB.INS
look at dye sub, that will allow the metal to not have an edge that can be picked at like screen printing
jrsc
It sounds like there is a little confusion on the finished product. Just to make sure we have it right. You want plain silver metal with all black text and logos. So silver background and all black imprint. Also do you have a preference on the type of metal used and what type of application is it (indoor or outdoor).
We do laser engraving, uv printing, and a little dye sub so I might be able to point you in the direction we would find easiest.
BESTBLANKS
Sublimation on metal and much more!
Hello, perhaps we can help. If you want to produce a high resolution and durable finished product then sublimation printing on metal is ideal. We are a full line sublimation supplier/wholesaler and we carry sublimation systems and blank sublimation metal, if you're interested in going in the sublimation direction.
Please see this link http://www.bestblanks.com/sublimation.html for sublimation printers, inks, etc.
For the sublimation metal blanks please see this link: http://www.bestblanks.com/chromaluxephotopanels.html
For all sublimation blanks that you can produce with sublimation printing please see this link: http://www.bestblanks.com/subblanks.html
Should you have any questions please give us a call! 888-431-7385 or 954-989-1250
Thanks for your post!
www.bestblanks.com
petepaz
silk screen would be the least expensive but i would say metal photo would be a good way to go. metal photo has a good appearance and will last for ever
rdm01
This is correct. No preference on the type of metal, they will be mounted indoors.
FireSprint.com
Trade Only Screen & Digital Sign Printing
Edit: I realize we would need to print on the bare metal. Although it is possible, we don't stock an ink line that will stick to it. Bringing in the ink and adhesion promoter would eat up everything in the job for both of us. There's got to be a MM that does this kind of stuff regularly though.
rdm01
Ahh, still can't find someone who can screen print this thing or give me a quote for laser. I have had three dead ends at this point. Any help would be appreciated!
(note: FireSprint, you aren't one of the dead ends, thank you for at least giving it a thought!)
parrott
We screen print with 3 different ink systems (enamel, solvent & uv). I would be happy to quote the job for you based on one of our ink systems adhering to your material (which is rarely an issue), but we are a good ways away. Please PM me the specs if you are interested in a quote.
jrsc
There is a silver aluminum we use that lasers black. I think it might work for your application.
FireSprint.com
I'm going to put a quote together. Although it won't be as competitive as I would like, at least it will give you something to go on. I'll PM it over in the next few hours, even if it's just for a reference.
Thanks!
