Thanks Justin,
My situation was firstly the ink on the black printhead to the cartridge didn't flow, when I opened the connector from the black printhead, the ink was sucked in to the cartridge line.
And now thinking of changing to 4 colors configuration will move the Lc head to replace the black.
Your explanation was quite clear for me, and just want to make sure the following:
1. I have opened the prime pump and takeout a bigger line that go to the cap, is this from here we will suck the ink with syringe ? ( I will find the correct connector).
2. When You input the printhead detail in CP Manager, was the printer still on cap cleaning State?
3. When you finish installing the head, how to bring the ink flow back from the cartridge to the printhead line?
Do you need to recharge the ink before we do the test print or not necessary?
Thanks again to you.
Cheers,
Hi,
I've taken a photo of the connector (and hopefully attached it) that I use and has a tube attached for my syringe. I think this is the exact same connector you will see in your machine and will have to unscrew the plastic hex nut from the tube then connect your connector like mine and hook a syringe up. This process is essentially doing an ink charge just on the one line you have connected it to.
1. I think that is right, compare with my connector. Basically it's the tube that comes down out of the cap and connects to the pump connector.
2. The printer will not be on cap cleaning state once you turn it back on, the head will automatically move back to the home position and printer should just boot up in to 'ready' state.
3. As above, the process of using the syringe to pull the ink through is essentially a charge, ink will come through the lines, in to the head then down to the cap station. Once the line is full and if ink has hit your syringe (excusing any ink that might have been in there at the very start) you will know it is charged.
Just to advise again, I am still new to this, I believe all this to be true and correct and this is the process which I was trained to replace the heads by a very knowledgeable qualified tech. As I said before, I have replaced 2 heads using this procedure, one was at least 2 months ago and all is well, the other about a month ago and also all is well.
Happy to help
