Sharpie on laminate
Kemble
A customer reached out because their wrapped box truck was vandalized with Sharpie then left to bake in the sun. Any suggestions for how to remove the Sharpie without damaging the laminate/print?
tyia
Boudica
Mr clean magic eraser. Or ISO alcohol and a lot of elbow grease.
d fleming
You would be amazed (or maybe not) at what rapid remover can do. Or even wd40. Maybe.
myront
Dammit, make it faster!!
try a dry erase marker over the sharpie. I have heard it works, but have never had to try it
You can also go back over a small section at a time with a sharpie again but wipe it right away.
Stacey K
I like making signs
Tell them to go over it with a dry erase marker! I've done it on various things and it works great!
JBurton
Signtologist
+1 for the rapid remover, +2 for the only solution you can bill them for aside from ipa & acetone, +3 for telling them to get a magic eraser and kick rocks (but these actually work by abrading whatever surface you're cleaning, it may dull the gloss laminate pretty noticeably if they really go to town on it. Also, always wear gloves with those things)
Kemble
Ty for all the replies. I’ve forwarded them to the customer. I’ll let you know what worked for him.
rydods
Member for quite some time.
I may be incorrect about this but after using a product like rapid remover or possibly some of the other suggestions, I would have the customer clean off these products with a mild cleaner like soap and water. Some may dry out the laminate if left on there. Just to be safe.
tyia
rapid remover does pretty well at taking sharpie off laminate without burning the overlam.
Reactions: 1 users
